Twin wardrobe's for dressing room
Silken
17 Jul 2024
This was a small project for my daughter, she just moved and was using temp hanging units for cloth's. As it's a dressing room there was no need for door's. I used 3 x 18mm MDF sheets for the carcass's and 2 x 5.5mm plywood sheets for the back; and used confirmat Screws M7 x 50mm screws to assemble.
I used a 7mm wood drill bit to form a pocket for the head of the screws and a 5mm wood drill to for through holes. MDF has a tendency to split unless you drill the holes and pined the backs on. The benefit is she can disassemble and reassemble next time she moves. Dimensions are height 180cm x width 90cm x depth 60cm, full length hanging space and storage on the bottom shelf.
This is the only photo, I have, it was late when I assembled them and very tired so forgot to take more.
I should have another to do for a friend of a friend soon I will try and remember to take more photo's :D
    29.5 KB
