Hi All...
this is literally my 1st project since school (20 years ago!).
iv built a simple router table which went pretty well. A little hick up or two but it works!!!
And now my project begins.
Basically my aim is to rebuild a plinth for a Rega turntable as mine is currently in a bad way. I will also be upgrading a few elements here and there and hopefully make for a better quality product in the process.
And here is my 1st peace....
This was cut roughly with a jigsaw, trimmed down with a plane, and finally trimmed true using the router table with a trim cut bit.
Apart from some very fine tearout the quality of the cut is stunning, im really happy with how that went.
From here I need to cut a cavity on the underside for the motor housing, and a few channels for the power leads/on off buttons (another job for the router). I then plan to bond a 2nd sheet of ply to the underside to hide the channels for the leads, and make the plinth more solid and substantial in the process (this should also aid sound quality).
From there is drilling holes and attaching feet.
I think all the above should be pretty simple.
From there its onto finishing...
Im thinking I would quite like to keep the exposed ply on the edges. And I like the idea of a clean white or black laminate for the very top. But this is less of a concern at the moment.
Anyway....Given this is my 1st project I would love to hear any thoughts, comments or tips! because quite frankly I could do with all the help!
cheers!
cheers!
