CHJ
Struan":2bavpebg said:......If you don't mind my asking, how did you dry them and what finish did you use? ....
Struan, if I am turning green wood I treat it like This and rough turn it to speed drying.
Timber in general is always sealed on the ends with wax or old paint as soon as possible after cutting.
If cut into rough blanks then thes are either end sealed or periphery sealed immediately.
If not cutting into blanks, sections are stacked outside in the shade (ends sealed) and left in as long a length as possible to reduce end splitting waste.
If cut into rough blanks for drying then they are sealed and stacked under loose covers to try and equalise moisture gradient in the stack.
The most significant action with any log to be on the safe side is to split it through the pith to reduce random radial splitting whilst drying.
This is typical of what I am using at the moment.
click on images for larger view
