cd,
Pen finishing - I have tried the following:
For wooden pens I have tried various methods.
a. sanding sealer, flattened with 0000 wire wool, then waxed.
b. sanding sealer, flattened, then melamine lacquer burnished with burnishing cream, then waxed.
c. the method I have finally settled on, quick and easy with just as good results, friction polish followed with a polish with carnauba wax from a stick with the lathe running at high speed. I have turned three ebony pens this evening. An absolutely filthy wood to turn but a brilliant glass-like finish achieved with this method.
I have also turned acrylic and corian for pens. I use a 3/8" beading/parting tool, used as a scraper, horizontal on the tool rest to provide a finished surface on the blank, then a light sanding with 1200 wet 'n' dry, then burnish with the cream, followed by friction polish. Prior to discovering Chestnut burnishing cream I used car rubbing-down compound on these, followed by car polish. That worked okay too.
So, having gone through all my trials and errors, what it comes down to is - friction polish. My only reservation about friction polish is that the finish may not be as durable as, say, a lacquer. However, as it is speedy and I've not had any complaints so far, I'll stick with it for the time being.
Cheers,
Trev.
