Hi, first post and help requested.
I've just acquired 2 turning chisels (or at least I think they are )
They're 22" long overall, handle 11" +3/4" brass ferule, made by Ashley Iles Ltd.
Blade is 1 1/4" X 1/4" section with short edges rounded.
The cutting end is at right angles , i.e. ___________
Sort of like: _________/__
But the grind is sort of diagonal, i.e. on each face a triangle is ground away
and when viewed end on the blade / sharp edge is diagonal across the 1 1/4" X 1/4" section
Sort of like:
As I said, I have 2 of these, one where the diagonal blade is top right to bottom left, the other is top left to bottom right
If you rotate the above diagram by 180 degrees you will see it stays the same
So I guess these are left and right hand versions of whatever they are.
Can you tell me what they are and what they're used for?
Sort of like:
