SketchUp Guru
tnimble:
Ah, very good. While I didn't talk about that in my tutorial, that is an excellent method for keeping the file size down. If you are planning to add a mortise for a skirting bboard or a stretcher, it would be a good idea to split just the turned pat or split the leg component further into turned and unterned sections.
To answer your question, the way to make the seam line between components smoother is to place it in the neddel of a face rather than on the edge between faces. To do that in this case, you would rotate the turned sections before adding the square parts. Or you could rotate the path prior to running Follow Me. For the default 24-segment path you would rotate the shape or path 7.5°.
If I was drawing a leg to use in a project, I would rotate the path and then make a quarter circle arc for the path.
