Dibs-h
I'm busy making the 2 Kingpost trusses (main workshop thread) and will be using pegs to peg the joints. I've got details on the min distance away from the mortise shoulders that the holes need to be bored.
I've come across mentions of using draw boring and tapered pegs - makes sense (later shrinkage etc.). Question is where does one get them from - or DIY? I don't have a lathe so was thinking that the taper isn't likely to be uniform - or does that not matter? I suppose lengths of 20mm dowel in a pillar drill and some lengths of coarse abrasive cloth should do the job.
Or is it overkill and constant diameter pegs do the job?
