Unfamiliar with either the router or the table but there is not a lot that could be wrong.
I am assuming that the table has a 240v socket into which the router plugs, and that there are then external on/off switches.
So router should be switched to the on position and if necessary any secondary safety switches also latched on - I've seen some cable tied to the 'on' position, plugged into table and table plugged in.
Table switch should then power router.
If not, eliminate issues with the router not switching on by plugging it directly into a socket and turning the socket switch on. If that works then there is presumably a fault with the table switch (fuse maybe?).
