Hello Everyone,
I purchased a Triton TRA001 router about 18 months ago but never used it until this week (Due to time and building a table for it)
It is fitted to a router table but for some reason the 'chuck assembly' as Triton call it comes loose and hence the router bit then comes loose.
Just to be clear, the bit sits in the collet and the collet nut tightens onto the check assembly. When it comes loose the bit is still tight in the collet and done up onto the check assembly, which seems like another treaded part which in turn screws onto the motor shaft.
As the motor turns freely, their is no easy way to tighten this up and it does not have any flats to do so either.
It would seem that it would 'self tighten' when routing. But it just comes loose and the bit wobbles all over the place!
Any suggestions? Unfortunately, I did not register the router so did not get the two year warranty.
Paul
Paul
