charleydavidson
Just got a B&Q Triton router to replace Trend T5 in a 5 yr old 2000 workcentre with horrible clamp fittings to attach router.Considered looking for "the UNC screws" to attach directly but wanted to be able to remove the router quickly when required.Spoke to David at Woodworking centre in Northamptonshire 01604 494549 (no connection),very helpful and knowledgeable they suggested the router table upgrade RTA423 13.37 plus 5.45 carriage plus vat = 22.11. It arrived next morning amazing service.This provides a secondary plate which is bolted under the existing router plate with keyhole slots allowing you to utilise the two spring loaded attachent bolts present in the router baseplate,no missing screws just press twist and tighten.You probably lose 5mm depth of plunge but the Triton is good in this respect anyway.It also comes with four clamps to attach non triton routers,(I now have a small collection of various styles of these)
What are people using for template guides? the triton kit is quite expensive,they don't say if the templates are metric or imperial and the 30mm guide alone for kitchen worktop jig is a further 10.00 pounds.Trend make a plate specifically for the triton still expensive but guides are cheaper I think,(the unibase doesn'fit}.I also considered filing keyhole slots in the black plate that you can use for overhead trenching but it didn't seem to have much room without weakening it although I tried fitting the plate supplied and it would do the job,just appeared a little skewed.
Any hints/tips welcome
Thanks charleydavidson
