Hi All
My Trend Airshield Pro's battery has slowly died on me and on looking I couldn't believe they are £35-£40 so I opened mine up very easy apart from the elastic glue they use to hold the batteries in, just unclips and inside there is three batteries (cells) a bit larger than AA's so I went online and one place showed that they are 3.6v, 3500mah Nimh so I thought that can't be to hard to replicate.
So looked on eBay and came up with these AA's I couldn't find 3500mah only 3000 but I thought that will do so I bought 4 for about £4.00
All I did was copy the original layout I scratched the connectors then heated a blob of solder onto the wires then as soon as the solder melted onto the battery I removed the heat do this as quickly as possible so as to not damage the battery, I'm so dumb when it comes to electrics that I have no idea what the little white box that I've soldered even is, so if I can do it anyone can?
Then clip it all back together switch on and depending on the state of the batteries when you get them charge wise you should hear the fan I let mine run right down and then gave it a full charge and all is going well can't say if you will get 8hrs like the original states I never did but I've had it on a few hours today and it's going fine, a few more charges and it should last almost as well as the originals and all for the princely sum of £4.00 but sshhh! don't tell anyone...
