Trend Air Max Pro
morpheus83uk
31 Dec 2017
Manchester
Hello,
Happy New Year!
So over the festive season I treated myself to a Trend Air Max Pro so I didn't have to use the faceshield, Ear Defenders and Half Mask together which is very cumbersome. So I fitted it and tested and it all seemed fine. I did about 2 hours turning yesterday and today with it and apart from getting used to the weight on my head I like it. I do have one issue with it though which I am hoping anyone can help with.
When I have my head down turning something the red light comes on but when it look back up again it goes back to green. I have tried:
  • Charging the battery to a full charge but still the issue persists
  • Removing the pre-filter and still the issue exists
  • Checking the fit of the HEPA filter (which is the original from the box) and still the issue persists
  • I have checked the filter using the test of blocking the air flow to check the red green light changes which it does.
  • I have tried this with and without the ear defenders without any joy
  • Also played around with the fitting of the respirator to see if it was something with hat but no!
On occasion though the red light will stay on for a second or two when I lift my head but sometimes will remain on. I have been through the manual and tried everything that it says so I am not too sure if its something I am doing wrong / have done wrong or if its the unit which is broken?
Has anyone experienced this or have any idea what it maybe? I have also Emailed D&M Tools where I got it from but I am just asking for advice from anyone else as well really.
Thank You All
James
