stuartpaul
Tormek Supergrind 1204 (believe it's now the T4?).
Had this a while and it isn't being used. Started off with a 200 mm wheel and it's still 197 mm or very close to it so not masses of use.
In addition to the standard flat blade jig it comes with the universal gouge jig (SVD-180), Gouge jig (SVS-40) and a grading/dressing stone (not pictured).
There has been a repair to one of the tool rest mounting posts (pictured) but this does not affect the use at all. There is also some light surface 'discolouration' that you get with older alloy that's been sat for a while.
I've seen mention of concern that wheels can get stuck on and are impossible to remove, - this one was removed for storage so is easily replaced.
Looking for £140 plus postage (it's heavy due to the wheel). Located in Somerset (TA18) if collection is an option.
