PowerTool
As another CCBL owner - same problem,same solution (am in the habit of checking and tightening if required each session)
Andrew
Andrew
Been there, with a small Record lathe. The answer in that case was an engineer's scraper, and a lot of elbow grease to get top and bottom surfaces of the bed parallel to one another. Actually, it was not <that> much work, with a good scraper.Paul.J":23d0pe8t said:Your right Chas.There is too much discrepancy on my lathe bed which is why i left the nut as it is,but i will give your method a go.![]()
Paul.J.
