If you want to buy something with the best dust extraction on the market then buy Festool, if not then buy some other make.
True enough. If you were in business making this sort of 'stuff' then the Dominatrix has to be an essential and you'd be out of your tree not to have one. But as an amateur or hobbyiest you'd probably find an alternative way to cut 300+ m/t's...p111dom":22xktjky said:It is true though that there is no competitor for the Domino. Things like this would have taken ages without it.
woodbloke":1agh7y4e said:True enough. If you were in business making this sort of 'stuff' then the Dominatrix has to be an essential and you'd be out of your tree not to have one. But as an amateur or hobbyiest you'd probably find an alternative way to cut 300+ m/t's...p111dom":1agh7y4e said:It is true though that there is no competitor for the Domino. Things like this would have taken ages without it.
It's the old time issue again :wink: - Rob
p111dom":3vzw0wo4 said:I find the extraction on the OF1400 ok if you're not going all the way through like cutting a rebate but when routing an edge, with the lower section of the cutter exposed, it makes about as much mess as my other routers.
Your straying into Wakansian territory here...some of us are well heeled (even if pensioners :wink: :lol: ) and some, unfortunately aren't, like me. Even if I had the available wedge to splash out, I doubt the Dom would get used more than a few times each year, which on a £sd/use basis makes no sense whatsoever.p111dom":3b9nhlaj said:For a well heeled amateur where it's not the end of the world if it breaks and takes a couple of weeks to get it fixed, I find Festool make more sense.
Chems":2y5hkgbl said:p111dom":2y5hkgbl said:I find the extraction on the OF1400 ok if you're not going all the way through like cutting a rebate but when routing an edge, with the lower section of the cutter exposed, it makes about as much mess as my other routers.
Have you got this Dom?
http://www.mtmc.co.uk/product.aspx?ProductID=38860
Designed to combat that type of cut.
ramp34":2qanu9zw said:so the domino seems to be a worthwhile buy from what people are saying, is there anything it cant do?
ramp34":2wj4e5ni said:so the domino seems to be a worthwhile buy from what people are saying, is there anything it cant do?
ramp34":11qh6xd9 said:... is there anything it cant do?
Chems":3cv47zah said:There isn't really a comparable system on the market, there is the dowel max, and the miller dowel I think it is...
wizer":3haxjaid said:p111dom":3haxjaid said:Things like this
Dom is 'Festival Domino' a typo? I only scanned the article, but it seems like it is. If so, that's got to be the fcuk up of the year!
p111dom":91vgivj6 said:Think I will splash out and get one then. Will order it on line if it's in stock but my dealer won't have it and like I say ordering anything from Festool takes ages. I mainly bought the 1400 as that was what was recommended for the Leigh jig but it can be a bit heavy for this. The biggest problem I have with the 1400 is that the larger radiused section of the base is on the wrong side of the router for a right-hander. Consequently I use it left handed on the Leigh to allow the wider base onto the fingers. The other way round it's a bit tippy. I had thought the OF1010 might be better for this but ruled it out immediaty as the one I saw had the poorest looking fence of any router of a similar size. I haven't seen one for a while in the flesh so hopefully in the mean time they've upgraded it as a slightly smaller router would be nice.
