To buy and restore a Wadkin Bursgreen 12BRT cabinet saw or not?
Wayne in Oz
New member
11 Mar 2025
Melbourne, Australia
Hi everyone,
Firstly, I have already posted this on the 'woodworkers forum' as a lot of Aussie chippies frequent that site, so apologies if you've already seen my post. I'm posting here because the UK is the home of Wadkin Bursgreen machinery so I anticipate getting a lot more advice here.
I am a keen hobby woodworker who works primarily with solid timber, as opposed to manufactured boards. In addition to making furniture, I love restoring tools and keeping them as original as sensibly possible. I'm looking to buy an old cabinet saw to restore. I already have one money-pit (a boat) and I don't want to spend quite a few thousand dollars on a new saw.
I have found a Wadkin Bursgreen 12BRT saw that appears to be in fairly good condition and, importantly, complete (except for the sliding table). It's a 3-phase machine and my cunning plan would be to replace the motor with a 3 HP single phase motor that I can run off my dedicated 15 Amp domestic supply. I don't think I'm under any illusions about such a project and what it may involve. I believe a motor stands to cost about 200 English Pounds and I would almost certainly replace the arbor bearings and drive belts. I would also have the arbor and blade support checked to see if they turn true so there's always a risk of unforeseen additional costs. That's the nature of restorations.
If I could pick up this saw for between 300 and 350 English Pounds, do you think such a project would make sense? Would I be better to buy an AGS model? What am I looking to achieve? - 1. an engaging project and, 2, a heavy, bullet-proof saw that I could not afford to buy new. Thoughts?
Cheers,
Wayne in Melbourne, Australia
Is a BRT not just and AGS with a sliding table. You say the sliding table is not present, and I doubt available second hand. If that’s the case you may as well get an AGS, unless the BRT is a steal locally.
I have an AGS which I smartened up, replacing arbor bearings and deconstructed to clean. A simple machine to work on and bearings standard size ms so easy to replace. My machine has had a single phase motor fitted at sometime and there is no modification it just bolts on in the same place. If the motor shaft size is different you may need new pulleys.
I love my AGS.
Fitz
