I emailed Titebond technical support and this is what they said regarding Titebond II, asking what the shelf life is and how to read the code printed on the bottle, the code on mine is A112090035.
Titebond II has a conservative published shelf life of 2 years. But if kept in a good temperature controlled environment, it more likely will last 3 to 4 years. The signs of degradation are all physical. If the adhesive becomes very thick, or lumpy or stringy and does not wet out a wood surface well, it is going bad and losing bond strength. Titebond II will also sometimes get an orange gel separation, and that is a bad sign. However, if it is still smooth, creamy and wets out a wood surface well, it is still good. Your particular bottle was manufactured on 12/09/11, so it is a good fresh bottle. In the future, you can interpret our lot codes as follows:
Current format: Aymmddbbbb
The first letter is A for made in America, the first digit after the A is the last digit of the year of manufacture, the third and fourth digits represent the month, the fifth and sixth digits represent the day of the month and the last four digits represent the batch number.
Example:
A904270023 – This material was manufactured on April 27, 2009
Thanks,
Bee Miller
Technical Service Representative
Construction Products Division
Franklin International
2020 Bruck St.
Columbus, OH 43207
614-445-1372
