Matt@Nearfield
Maybe an old topic, but certainly an interesting one.
On another thread I stated that I prefer to use a VFD with a vfd rated motor as I feel it allows me to ramp up the speed the saw tips are moving which I feel gives me a better cut.
Studies have been done to determine the optimum tip speed for cutting hardwoods, softwoods, mdf, mfc etc.
Obviously the speed you pass the material through the cutting teeth will play a part in this... pushing the material through at one speed or another will make a difference.
Also, most saws have a nominal recommended sized blade, but also have a 'range'. I've always though this was a riving knife thing. For exam[ple, my Wadkin I'm curently working on is a BGS 12.. so a 12in blade. but can take a 14in, but also anything smaller.
Perhaps we could touch on the benefits of running a smaller blade (I actually prefer a 10in in many ways) .. for me it's cheaper and quieter.
Now the contention seems to lie in the fact that I prefer to have a slightly higher than the manufactures arbour speed and this is aparantly completely wrong. But after many years and many saws I've found a higher tip speed gives me a better cut.
Is this because I mainly bash out 18 or 22mm mdf sheet to make cabinets. I appreciate theres a loss of torqe, but I never run 3in hardwoods though the saw so not a real concern.
Is this because of the speed I push the materia through the blade?
Is it because the manufacturers tried to come up with a best compromise that will suit every potential use rather than end user specific (I expect so). Like a 2ltr engine for a 4x4 vs a sports car?
Is it becuase I prefer to use the much smaller gulleted teeth of PCD blades for the man made composite wood products I use?
I'm sure that math will come into this, so a few numbers:
Wadkin BGS 12 - 12in blade, arbour speed 3200rpm
Wadkin PK - 18in blade, arbour speed 3000rpm.
Just interested in other peoples opinions?
I've made popcorn..
M.
I've made popcorn..
M.
