If a rotten small section of window cill had to be cut out and a new piece fitted what joint would you use?
I saw one today which had been replaced about a year ago and the carpenter had just used a mitre joint.
The result is that one year on an unsightly gap of around 2mm has appeared between the sections.
Would a scarf joint be better or something else?
