Box sash windows
It's not that it's a bad idea it's just not how it was done. If it was proof against it ever rotting I would consider it but after 100+ years these windows can basically turn so dry and twisted water can penetrate In a multitude of spots. Making them with a housing is my favourite bit oddly it's just a rock solid joint with the sizes set by the inside of both housings.
I totally understand why the original sliding sash windows used a wedge and groove at the junction between the pully stile and cill.
The wedge tightens up the joint to prevent shrinkage and stop water running in the groove but over time shrinkage plays it's part and water inevitably makes it's way into the groove and the rot starts. It was known many years ago to be a weak point and the wedge was a form of preventing shrinkage opening the joint.
It is normally only the corners of the cill on a sliding sash window that go rotten and it does usually take some years to happen so it's overall not a bad design.
Thanks for all the photos. There’s a good Youtube video where he demonstrates making the housing in the cill for the pulley stile to sit into. It’s titled “how to make box sash windows in oak part 1” (skip to about 13.40)
Are you wanting to make them totally traditionally? or do you want a window with modern performance taking DGU? If you go on Mumford and Wood's website you can register and download their CAD drawings. (I'm sure that isn't what they are there for......) I used their conservation range as the basis for 8 windows I made for our house. https://www.mumfordwood.com/product/conservation-range/box-sash-windows. It didn't take much to adapt their profiles to standard router cutters and to take off-the-shelf beadings and seals.
I used Accoya, domino'd joints, internally beaded and dry glazed with 24mm DGU, and with weight pockets on the inner lining not the pulley stile, with a variety of different seals, clip-in parting and staff beads. Painted in Teknos aquatop, five years on and they are still perfect.
The photo is my test piece when I was working out clearances for the seals I was using.
    227.3 KB
    163.6 KB
I too was considering spiral balances, I figured that since my original rebated reveals have been bricked up I wouldn't have space to make weights work without it looking weird. But I was walking round Beamish the other day and noticed that a bunch of their windows are just installed in a flush reveal anyway and you wouldn't question it. I think they're probably salvaged windows that they've made fit. But the difference in frame size between weights and spirals might actually be less than you think, and there are some rectangular weight sections that you may be able to work with to squeeze them a bit thinner too.
Still early days, but the most confusing thing to me so far is the sealing details. There doesn't seem to be a clear "best practice" option, just a list of options as long as your arm. But it's quite an important thing to get right. Some have a seal on the parting bead, some have two seals on the inside and outside of each sash, there can be all sorts of different brush seals and compression seals depending on where it is on the window...
I can imagine a way of doing most things with basic hobbyist tools, but the one thing I haven't seen a good method for is making the stepped cills. All the youtube videos use some crazy industrial router or circular saw setup. I guess you could hand plane it, or is this something people tend to buy pre made?
    136.1 KB
You can buy the sill. ( Along with most of the other components for making the sashes.) :giggle:
If you want to do-it yourself, then an electric hand-plane is good for removing most of the stock from the sloping sill.
If you are going the all hand-tool, route, then you will need a combination plane that will do your grooves. It can also form the sash stock - if you have the right cutters. You might also need, a rebating plane, for the bottom part of the stepped sill, though you can get away with ploughing a groove, first, to form the step and then using an ordinary bench plane..
You will find it useful to make a ply/ MDF template of the sill profile to draw around at both ends of the stock. And, it will be there for future reference.
I have seen the sills made in two parts before, the main part made of something like 6"x3" with a bevel on the front half then a piece of something like 3" x 3/4" with a bevel on planted on top to form the step if that makes any sense.
Regarding seals I like the hidden compression style around the outside of the sashes best as you can't see it.
I suggest seal the lower sash by routing in a pile carrier channel 8mm by 3mm along the bottom and one accross the meeting rail.
Then use parting bead and staff bead with built in pile carrier.
If the parting bead extends over the head then there is no need to apply pile carrier to the top sash, if it doesn`t then use it there as well.
I prefer the 2 part plastic parting bead as you can pop it out for maintanance easily but you can get wood ones if you prefer, the reason I suggest using the beads with carrier rather than built in pile is because then you can choose which pile or Schlegel type seal you need for the particular gap.
I would also advise fully painting the sashes before adding the self adhesive carrier to ensure a really good waterproof seal there, do the channel a little oversised to account for paint.
I do not believe there is any advantage to putting a seal on the edges of the sashes and have often seen these causing binding with seasonal movement and I always remove them if I refurbish a window with them on.
Mightons version of the plastic 2 part parting bead is better than the reddiseals one, also their beads are cheaper in general and good quality, the stick on pile carriers are the same.
Jewsons stock box sash cill but they call it door cill its Meranti and varies in quality a lot I always used to try and find the heaviest ones., I make my own now from Utile, don`t let them charge more than about £35 a linear metre because they will try it on !!
If making new boxes use the pulley covers that go on the inside of the box as well.
Do not use spiral balances, just no advantage to them. They are difficult to balance perfectly, the metal bracket is a nightmare with tiny screws that will eventually lead to rot in the corners and rust out. They will break at random eventually and they are inclined to smash you in the fingers with the winder when installing them.
A well balanced window with weights and cords will work effortlessly.
Incredible and useful thread, I am also in need to fabricate a dozen of sash windows to replace the badly designed and rotten ones we have on our cottage.
Earlier this years, I took on making 4 casements windows and a front door as my first wood working project ever. I used more modern techniques by using dominos instead of traditional mortice and tenons joints. Luckily i had a the help of my 70 year old neighbour who is a very experience DIYer carpenter and made the common and non common mistake in his earlier days. It was much easier than expected and it went well so now I am getting ready to start working on my sash. I am also contemplating the idea of building it in a more efficient/DIYer friendly way without compromising the longevity of the window.
I suggest we keep this thread going with the various on going construction/fabrication updates from people like me who are tackling this for the first time and the feedback/suggestions for the more experience. It could become a very solid source of infos for the future beginner makers. Yes there are a lot of resources on line on how to make it but a lot of them shows the use of machinery that most DIYer don't have access to. The previous posts above highlighted some of those challenge already with the stepped cill for example.
One question, I see that pine was suggested for the box, would it not be better to use Accoya for all of it (box and sashes)?
