Hi all - hopefully someone in the know can clarify this for me.
Just to make clear up front - with hindsight I know I should have probably bought better quality decking boards. But I've got them now and can't really afford to replace them all just yet so I will have to make do for the moment.
I'm currently building my decking which is my first big woodworking project. I'm only entry/intermediate level at woodworking, but I'm pretty happy the overall frame is built well, all the joists are placed correctly and level, and that there's a small drop built in for drainage. My laser level says it is all good.
I bought decking from Wickes about 3 weeks ago advertised as 3600mm x 140mm x 28mm. Wickes advertise it as "slow-grown premium European Pine". It sat around for about 2 weeks in varying hot/cold/wet conditions before I finally laid it last weekend. All seemed OK until I realised I needed another 10 boards to finish the job so I paid someone to go and pick them up in a van so I could fit the remaining 10 boards the same weekend.
It wasn't until I laid the remaining boards and walked around that I realised there was a 2mm drop in thickness between the first batch and the newer batch. The original batch measured exactly 28mm, but the boards I purchased and fit on the day only measured 26mm thick.
The "newer" boards have been fitted for nearly a week now, have experienced hot/cold/wet conditions but they are still 26mm thick, and there's still this annoying drop between the "old" and the "new" boards:
To add further confusion to the mix, after yesterdays/todays rainfall, some of the original "older" boards seemed to have crept up to 29mm and even 30mm thick in some places. The newer boards are still holding at 26mm which is exacerbating this issue as the drop can be up to 4mm in places...
My initial thought was this is just a waiting game and that I should expect this issue to resolve itself as the newer boards swell up to 28mm. But my doubt is due to the fact that the decking boards seem to be manufactured differently. They have different labels which makes me think they have probably come from different manufacturers?
They also have different cuts, the newer boards have sharp edges, where as the original boards have a rounder edge.
Any advice on what to expect, or possible solutions would be much appreciated!
Jamie
Jamie
