No skills
Hello again
To go over the impending new front door I want to build a canopy, the design is a straight forward flat canopy (roughly 18" projection from the house) with pillars either side (instead of brackets) that go to ground level - projection of the pillars roughly 13".
I would link to a picture but I can't find the exact one I found a few months ago :roll:
The canopy part is timber/ply construction dressed up with a moulding round the outer edges, membrane or felt topped with a through gutter outlet etc etc.
The pillars is where I'm stuck, I don't want to do brick/block as I'm **** at it and no one seems interested in doing such a small job. That leaves me with timber pillars, tiny stud walls clad with... Hmm... Redwood/pine treated with a preservative and then painted??
If I went with that how should I do the corner joints? A long mitred edge would surely open up in short order?
Any thoughts on those?
