sploo
Somewhat extinguished member
Yea, it is a shame. The two units have similar serial numbers (approx difference of 90).woodpig":3k3gvf0t said:You've been very unlucky. Mine runs like a sewing machine and there are lots of others out there that run fine. I'm really intrigued now to know where the noise is coming from. I'm also wondering about the "drum" effect of your bench?! :wink:
The drumming sound is simply because the machine is vibrating. If I cup the motor with my hand I can feel it "kicking", and that's obviously causing the bench top to vibrate. If I bolted it down to a slab of concrete I'm sure it'd help, but I'm reasonably confident the standard legs (which I haven't got) would also suffer - i.e. the problem isn't because it's on a bench.
I was also looking at the Jet 1221VS, but went for the Axy due to the motor. Perhaps the Jet's cheaper motor has allowed a bit more quality on the rest of the construction. Certainly I'm beginning to wonder if I made the right choice. I'm not sure I want to risk another 1416VS at this point, but do I go for the Jet or sink cash into the 1628VS...
Well, they did actually say they would check the new one first, but obviously I can't be certain if it'd been opened and tested (though I can take a guess).NazNomad":3k3gvf0t said:Still, it was nice of them to make sure the second one was perfect before sending it. :roll:
