GF Fittings
To make the connection right, Georg Fischer Fittings supplies threaded fittings and compression fittings made of malleable cast iron for demanding applications.
Show Products
Founded in 1833 by Georg Fischer, the plant in Traisen/Austria, produces pipe fittings that have proven themselves for more than 150 years in demanding applications such as gas or drinking water installations in buildings. More than with any other product GF has shaped the craftmanship in piping construction with the malleable cast iron fitting and its thread connection. The extensive range of fittings enables maximum efficiency through the minimum number of fittings and joints.
Simple installation and assembly
Primofit compression joints are simply tightened with a wrench, while malleable cast iron fittings are precision-engineered to ensure a tight fit.
Safe and resistant
Manufactured from high-quality, easily galvanizable cast metal, the material guarantees a long service life and reliable function of the fittings.
When quality is required
Whether material or construction: The production facility in Austria meets the highest demands and supports customers all over the world with technical support.
150 years of expertise in fittings
Thanks to their 150 years of experience, Georg Fischer Fittings is able to design and manufacture with the user in mind.
Products
Malleable Cast Iron Fittings
