Threaded insert removal
rs6mra
22 Jul 2014
Hertfordshire
Hi,
In the photo is a threaded insert in a metal tube/pipe. Any suggestions as to how I can go about removing this. I need to get to a threaded bit that's is within
Screw a length of threaded rod into it, clamp in a vice and apply force outward.
If you had a slide-hammer with a threaded attachment points that would be ideal, but capturing some wire rope round the rod between two nuts, and attaching the other end to a hammer, then swinging it so the rope suddenly goes taught is a sketchy, improvised way to accomplish the same.
Even less ideal ways include clamping a cheap vice-grip to the rod and braying on the vice grip with a big copper hammer.
Its called a star nut.
2 options.
1. Punch it all the way through.
2. Punch the wings about to deform them then use a threaded puller to pull it out. It will be hard going.
These are used on bikes with a threadless headset, they aren't designed to be pulled out easily.
Raid your tool kit and find the socket (there's usually one if you have a broad range of them) that has an internal bore that's greater than the internal bore of the pipe but just under the external diameter of the pipe...hold it on the end of the pipe and use a bolt with a thread (that matches the thread of the insert) and a washer that wont pull through the center of the socket and get screwing it in to the insert with the socket trapped between the pipe and the washer. Ratchet away until the bolt tightens on the washer and socket and keep going..if you're lucky, you'll be able to wind/pull the insert into the cavity inside the socket. ;)
