bogmonster
You are not missing anything - and I started with the same concern. I have not seen any others using the same design as mine before, as you say most have the rotary coupling on the tail stock side. My old lathe had a hollow spindle with a cross drilled spindle lock right through meaning it could not hold a vacuum. That meant either a rotary coupling on the headstock end with suction at the headstock end (tricky to DIY make) or pass a tube through. There are a number of options out there where the tube spins with the spindle and a coupling on the tail stock end but they all looked a PITA to instal and remove so I gave this a go first. Some stay in place until you need to use the morse taper.
To be honest the design started out as a quick prototype to test the new vac pump, I never expected to keep using it.
My original chuck was maybe 3 years old and although I have just replaced the chuck (different spindle thread now) I have reused the old beer line as it was still in reasonable shape. As long as you don't put a sharp bend in the beer line where it exits the tails stock it lasts a very long time in my experience.
Of course check from time to time and replace when showing signs of wear and long before failure. The beer line is a push fit (awkward and tight) into the bearings so is easy'ish to replace.
I have struck with the same design on my new lathe because it works so well and is easy to make and quick to take on and off. If it isn't broke don't fix it. Screw on chuck and push fit John Guest pipe coupler. The only downside is the chucks are a little ungainly to store with a length of beer line hanging out the end.
EDIT - just checked, the original chuck was made in June 2012 judging by my previous forum posts so a little over 2 years old.
BM
BM
