Hi Steve ... the motor is mounted at the opposite side from the headstock spindle...
So its right out the way of everything :wink:
It has the variable-diameter pulley system, so just the two pulleys that vary in diameter through a really simple arrangement when you shift the lever.
Its a fair beast, compared to what you 'expect' in the photo's that are found everywhere... big substantial lump of cast iron !
I cant fault it, for the £300 ( approx ) that it cost me...
and really easy to get at the 'gubbins' of the headstock for any maintenance that should be necessary.
Easy enough to assemble... its heavy, so an extra pair of hands would be useful. I did it myself, and a wee help out would have been good.. but its not impossible as a solo effort.
Thats the model I have F46-719
MT2 Tapers both ends,
1"x 8TPI spindle thread
1hp Motor
Variable speed ( mechanical not electronic )
14" swing over bed + headstock rotates, so you can happily go 'bigger'..
I reckon its been a good deal.... cant fault it for the money !
8) 8) 8) 8)
HTH
