SketchUp Guru
Tony, congratulations on the addition of the Rat in your shop.
I just thought I would make a comment related to joinery on the Rat. Aldel has a page or two describing how to cut dovetails. After the sockets are cut the tail board is clamped horizontally to the bottom of the base plate. The pin board is clamped in the cam clamp so it is under the tail board and the pins are marked out by scribing using the sockets as guides. Essentially doing as you would for hand cut.
This is required but I find it useful because I get immediate feedback when I'm cutting the joint. I've applied this for other sorts of joinery to good effect.
Now, before you start cutting dovetails please take a few minutes and do the following steps. It will save you a bunch of frustration and trial and error later.
Remove the router from the router plate.
Install the router plate on the base plate set up as you would for dovetails using the centre plate.
Slide it back against the rear stop.
Set the centre plate button setting to some convenient setting. Make sure you're reading the correct index mark for the location of the base plate on the extrusion.
Cam a straight stick into the cutter position so it sticks up though the slots in the plates and is flush with the top of the router plate.
Measure the distance between the back of the stick (which is also the front face of the Rat) and the centre of the screw in the centre plate.
Compare it to the setting you made and note the difference. Ideally they should match since that is what the button setting is supposed to represent.
I have two centre plates; one that came with the Rat and one I bought a few months ago. (I've had my rat for about 4 years.) With the old centre plate set at 60 the actual distance between the face of the rat and the centre of the screw is 57.5mm; a difference of 2.5mm. If I use the calculated setting for cutting pins, they end up too small. If I add 2.5 to the calculated setting they come out just right.
On the new centre plate the difference is 6mm. I expect that's due to a change in the way the labels are applied to the router plate and centre plate now as compared to 4 years ago. I'd be surprised if you find that kind of a difference.
I created an Excel-based button calculator that has a section for this correction so you don't have to remember to add it to your setting. For me this is handy. I started making a table, too, that lists the WoodRat bits as well as the Craftsman Gallery HSS bit and some TCT cutters. It has button settings for the common straight bits: 6mm, 1/4", 10mm, 1/2.
If you want a copy of that Excel thing--the calculator and the table are in the same sheet--I could send it to you.
