OPJ
I bought a second-hand Makita in 2008 and there's not an awful lot I dislike about it. It's accurate and it maintains it's setting (unlike the two cheap Ferms I had before). It's not as noisy as the cheaper tools but also, I can't imagine the Lamello jointers are any quieter (not that I've used one). Dust extraction is excellent once hooked up to a vacuum extractor otherwise, like all the rest; the port and blade housing will soon clog up with stringy shavings from solid wood (probably not much of an issue with the dust from MDF but then, you know the rest...). I quite like the case, too. Although, I've never really bothered to store any biscuits in the provided compartment.
On mine, the scale isn't quite spot-on so, I normally use a square or sliding bevel to set the fence to the correct angle. Occasionally, the E-clip that holds one of the levers in place (used to secure the fence height) will work itself loose (thinking about it, both clips were missing on the identical Bosch tool we used at college). That's not the end of the world though, provided you don't lose the levers. Out of the box, I found that the tool wasn't cutting slots deep enough, meaning edges wouldn't come together during an assembly. However, this is very easy to adjust and, for what it's worth, I did buy a second-hand model.
I'd certainly buy another, if this one failed. I really cannot see (without perhaps using one) what else the Lamello jointers offer... If you were to continue using your router table, would it help to fit stops (as when cutting a stopped groove or mortise) so that you can almost 'drop on' (or, 'in') to the cutter without the timber moving?
If only it had a feature to warn me when I'm cutting no.10 slots for no.20 biscuits! :-D
