A
Anonymous
Guest
I had this on my Delta Thicknesser
A new set of blades cured it 100%
Mark - good to hear you got it sorted...and as for the coffee - RobTrimTheKing":2yvkw8ws said:She only drinks latte's, which is mostly milk, so I think it's okay
You don't like Latte or you don't like coffee? She's a baby, she needs the calciumwoodbloke":2l15z71v said:Mark - good to hear you got it sorted...and as for the coffee - Rob
TrimTheKing":1affmaev said:Personally I take it Italian stylee, double espresso with sugar. Mmmmm, buzzing! :shock:
Tony":3nkrvhw0 said:I had this on my Delta Thicknesser
On their way mate, just need to put the baby to bed and have some dinner then i'll get them up here.OPJ":180zdirf said:Well, I bought a spare set of knives and have had both my sets sharpened several times. The problem has remained thus far (for me - I'm still waiting to see photos of what Mark did! :wink.
In this instance Stuart it is purely down to my personality.stuartpaul":1qkknyio said:And just how accurate do you need to be?
I've always been like this, it's a curse :lol:
Did that too...OPJ":hif9uv15 said:I'd have been trying to get the back cover off!
Yep, that's what I was getting. As I fed it in the end nearest me would fly to the left and slide along the raised edge of the bed, sometimes missing the edge of the cutter block.OPJ":hif9uv15 said:The tension on my machine is definitely a little 'slack' on one side and it seems to be the infeed roller. I doesn't feel like it grabs the wood as well as it does on the other side and I get a slightly uneven finish...
No probs, certainly got a fair belt off the bl00dy thing :lol:OPJ":hif9uv15 said:I'll give it a go and see what happens - thanks also for the tip on not electrocuting myself! :wink:
TrimTheKing":2wsn281e said:In this instance Stuart it is purely down to my personality.stuartpaul":2wsn281e said:And just how accurate do you need to be?
If it should thickness equally across the full width then that's what I want it to do, and I will pull the whole thing to pieces to find the problem if that's what it takes.
One last tip, just below the outfeed spring to the left there are two little microswitched boxes with wires coming out of them. Whatever you do, don't let the back of your hand touch one of them, while holding a spanner to the spring, with the machine plugged in...
Plugged in, NOT switched on, but your comment is very valid. I unplugged it in between every test after this, and will continue to do so...Boatfixer":1bxcdmk8 said:One last tip, just below the outfeed spring to the left there are two little microswitched boxes with wires coming out of them. Whatever you do, don't let the back of your hand touch one of them, while holding a spanner to the spring, with the machine plugged in...
The thought of putting my hand in any machine, let alone one with spinny blades whilst its still plugged in makes me shudder......
Graham
Absolutely no offence taken mate.stuartpaul":2r5fksm3 said:Mark, - please believe I'm in no way having a pop at you doing what you're doing and perhaps I should have started a separate thread. It's not a curse so much as a way of life!
wizer":3qzvwyn1 said:Tony":3qzvwyn1 said:I had this on my Delta Thicknesser
Did you even bother to read the thread? :roll:
