The wood slipped...
woodbloke
13 Apr 2006
Salisbury, UK
I was using my new spline jig on the router table to do some inserts for a picture frame for one of the lads at work...and the wood slipped :oops: I've put in the other spline to give the joint a bit of strength while I fitted the patch:
leaving me a curved and skewed slot which I needed to do something with, so I decided that rather than stuff the whole frame through the bandsaw :roll: :lol: I'd try and patch it, which was very tricky as it wasn't 'square' but curved.
Here's the first half of the patch in place with the grain matched, glued in with a fast set epoxy:
...and here's the second half of the patch in place and flushed off. Not a perfect fit, but close enough:
...so that when it's re-machined, the second insert can be made. Now the frame's finished off, it looks reasonable:
I know that the repair has been done, but unless the client knows what he's looking for my guess is that he'll never spot it 8-[ - Rob
And this, children, is why 'The Woodbloke' will go down in history as a legend...
Good save Rob
Looks like a decent repair to me, Rob. :)
If you haven't already cut the rebates, could you make this the rear of the frame?
Lovely save there Rob
I did something very similar on Thursday on a project I've been working on for several weeks :oops: :oops:
I posted this 'cos it's my view that no job is ever quite as we want it...there's always some sort of mistake, (in this case a glaring mistake) which we have to overcome and use a bit of ingenuity to make a 'fix'
Anyone else care to show any horrors that have been fixed...pics mandatory of course - Rob
Nice job Rob.
I recently posted a similar cock up https://www.ukworkshop.co.uk/forums/view ... sc&start=0.
It happens to us all as you say, it's just how you get over it that counts.
Rob you wouldn't believe the amount of 'wizers' that have gone 'through the bandsaw'. I have a toys/pram mentality when things like this go wrong. It's naughty of me. :oops: :lol:
