CHJ
A comprehensive list of useful Jigs posted by Nicky and Originally compiled in a thread by by Wizer and recently drawn back into the light by Devonwoody.
Different way of cutting 45* frame
Shop vac modifications
Drill Stand modification
Drill press table improvement
Screw cramps
Sanding blocks
Hold down clamps
For amateurs only
Cheap "Grip-it" clamp repair and improvement
Saw blade and router bit height guage
Cutting dado with hand router
Hand router bit height setting aid
Caliper (micrometer) modification
Another Shop-vac
Clean paint tray
Wild router table
Foam brushes
Doweling with router table
Drilling shelf support holes
Magnifying glasses
Straight edge on table saw
Feather roller, final version
TS fence memory
Dust free sanding
Hold down roller for TS *
Cutting strips on TS *
CS cutting table *
ROS DC improvement *
CS (or router) Offset plate *
T square *
Measuring tape - version II *
Construction Square - checking & adjusting to 90* *
Triangles *
Jointing with hand router II*
Checking diagonal, Version IV*
Logs or round wood cutting jig*
Router Lift for amateurs*
Triangles*
Amatorski Patentski*
Sanding Paper everywhere*
Screw clamps - long jaws*
Drilling small hole over large hole or vice-versa*
Even bigger triangle - "Copy" and "Past" *
Tenoning jig for table saw - it's rolling... *
New router - New table *
All seasons crosscut sled for TS *
Router table T-fence *
Router table fence setting *
Caliper modification *
My first box (finger) joint *
Rolling Mortise jig for router table *
Router Lift *
Rolling Mortise Jig - The test *
Hold-down clamps for...everything (LARGE PHOTOS) *
Cutting very small pieces on table saw *
Do you have a Saw board (AKA - circular saw guide) *
Crosscut Sled - my way *
Knobs - easy, fast and cheap *
Drill Press - holding wheels (knobs) and small parts *
Fence stops (yes yes, easy, fast and cheap) *
Circular Saw Guide*
Shop-vac "filter"...always clean...*
Thin boards glue-up *
push block *
Folding adjustable height table *
Cutting 2 mm strips on table saw*
Hold-down clamps - simple, fast and cheap... *
In memory of Niki! and his willingness to share and encorage.
[*]Images Lost
Clean paint tray
Panel glue-up aids
Panel glue-up, overcoming cupping boards problem
Sharpening
Lo-tech TS blade alignment
Threads edited out or superceded by Niki
Cross-cut sled, different way to make it.
Jointing with router
Doweling jig part 1
Doweling jig part 2
Feather roller for table saw
Push blocks
Feather roller - version II, prototype.
Amateur's working methods
Saw blade cleaning with STP
Router table fence distance and stops setting
CS with Zero clearance insert, why it's chipping?
Measuring tape, not only for measuring
Blade cleaner
Checking Diagonals
Checking Diagonals, version II
Checking Diagonals, version III
Glue line on router table
Thanks to Eric The Viking For finding the Archive PDF (Warning 69,231KB download) from the WoodWorkStuff as collected by Joe Lyddon site
* Images Retrieved and attached to threads 14-09-2017
Screw cramps
Sanding blocks
Hold down clamps
For amateurs only
Another Shop-vac
Clean paint tray
Wild router table
Foam brushes
Magnifying glasses
TS fence memory
Dust free sanding
CS cutting table *
T square *
Triangles *
Triangles*
Router Lift *
Circular Saw Guide*
push block *
[*]Images Lost
Clean paint tray
Panel glue-up aids
Sharpening
Doweling jig part 1
Doweling jig part 2
Push blocks
Blade cleaner
Checking Diagonals
