Stimpi
Every time a project comes to an end there is a time for reflection, what would I have done differently or, I am glad that’s over or can’t wait to start the next one. Usually its having a big tidy up, clearing the waste, short ends and the like, inspecting the tools and having a sharpen up before putting them back in their place.
In this process there is the constant moving about of certain items because they are in the way such as those bits of ply or that setting out rod. Are they really large enough to be useful? Can I use that rod again, a bit of sanding, a coat of white primer?
I have recently completed a set of cupboard doors for under a staircase and brought back kit from London to Sussex and started the tidy up process when a voice rings out all sweetness and light. “I have a job for you, I need a large planter.”
The setting out rod.
Same Rod different life as for a new gate
Cut up into strips
Screwed together a bit like a coffin
So to make it less coffin like a bit of decoration is in order which is good way to involve the grandchildren,
A fun time sorting out what to decorate it with, to which sunflowers were decided upon. A search of the internet made and then deciding which image would be best and how many sunflowers needed. One granddaughter wanted the rainbow but was out voted.
Some of the selection
Bits of ply from forming the staircase panels.
The selected image drawn on to the ply well within the capabilities of my 15 year old grand daughter
Three were made and cut up into sections. I did the cutting into sections and the girls enjoyed gluing them together. I also did sanding of the edges as the girls were worried they would damage their nails, but it was still good fun.
When all stuck back together a good time again in the painting
And then gluing and screwing to the planter
So ends the final chapter in the Life and Times of a Setting Out Rod.
Cut up into strips
