The joy Of Citric Acid
I have used both methods.
Never have I had the acid etching the metal.
Really, you couldn’t see the difference between the two? Using acid will etch the surface resulting in a matt grey finish. Using washing soda and a battery charger simply removes the rust, any shiny non rusty areas remain untouched.
I’ve seen many measuring tools and calipers etc ruined by attempts to remove the rust with acid.
The idea is that it makes sodium citrate, which is a chelating agent. Rather than just attacking with acid, that reduces the rust by pulling the iron out of the rust and into the solution. I think, being way over the ends of my crappy chemistry skis.
