Beau":13x006m2 said:mm all the way when accuracy is required
Beau":13x006m2 said:Yes imperial is great for rough work.
Absolutely. They're just as fruitful!bugbear":151fc7yu said:I love metric versus imperial threads. Right up there with sharpening.
DTR":2hwf3w3d said:Beau":2hwf3w3d said:mm all the way when accuracy is required
When accuracy is required, forget the numbers and transfer the measurements directly with the gauge / calipers / dividers / storey stick / etc :wink:
Beau":2hwf3w3d said:Yes imperial is great for rough work.
My lathe is calibrated in Imperial. 0.001" not accurate enough for you? (or 0.0254mm if that floats your boat?) :wink:
:twisted: :twisted: :twisted:
Beau":3qjr37jx said:Only having a bit of fun with the old timers![]()
phil.p":1hb1vt22 said:Pity they either did or didn't instead of the halfy halfy system we have now.
DTR":3e6d5o5y said:phil.p":3e6d5o5y said:Pity they either did or didn't instead of the halfy halfy system we have now.
Quite agree. Where's the logic in selling ply in 6 / 9 / 12 / 18mm sizes?
Woodmonkey":2zxdangk said:I just wanted to gloat about my new rulers!
I seem to remember that when McLaren built their facility near Woking they didn't want any "Mickey Mouse" stuff in it. I think the plumbers were banned from bringing copper pipe on site. Plastic was also frowned upon except for waste systems. I believe it was all done in stainless steel wherever possible. A great deal of attention to detail was also applied, all pipes had to be straight and level and an equal distance from each other. No pipes were allowed to cross any other pipes either. God knows where they found plumbers able to do the job to this standard. :lol:MikeJhn":23zi5xs0 said:And it gets worse, we are the only country that uses 15mm copper pipe, in Europe they use 1mm walled copper in 6,8,10,12,14,16,18,20,22 each one fitting inside the other for straight soldered joints without couplers, despite the change to PER and Multicouche by most jobbing builders, copper is still used by most half decent Artisans.
Mike
