Yesterday I was planing up some pine and paused to take the iron of my N0 8 to the sharpening stones just to touch up the edge. One minute later the iron was back in but it started to work in a way I've not experienced before: the shavings were coming out as straight lines, almost leaping out of the plane vertically and that irrespective of depth of cut and on three different boards. Normally they tend to curl one way or another. I read once on the internet that this means that a plane is working ideally.
This gives rise to two questions:
a. Is it indeed the ideal function?
b. What did I do right? The sharpening consisted of about four passes on a 3,000 waterstone, remove wire followed by about six on an 8,000 and remove wire. The blade has a very slight camber.
Secondly, the pine I'm planing is for a book case which will have a back made up of floating 1/2" thick boards running in grooves in rails at the top and bottom. I forgot them when buying the pine but I do have some American poplar which would fit the bill. The question is: if I paint the poplar e.g. creamy white, would it look OK? The book case will be up against a wall, so it will not be seen from the back and the back would obviously only be seen from the front and only then if there were significant gaps between the books. Would another colour look better with pine e.g. pale blue? (I'm clueless about arty things like colours.)
Thanks in advance.
Thanks in advance.
