" The Family " by toesy
toesy
14 Jan 2014
Me Garage in B'ham
We all have something we make, and overtime I am sure there are things we enjoy going back to making.
For me its the below, the frame is L = 525mm, H = 253mm
It is all cut from one piece of Cherry wood, which is 20mm thick, the names inside the Family letters I cut these last, once all cutting is done, I Danish Oil and them mount to the back board.
I have made a few of these now and all in all takes around 8 hours, I only make them for family and friends, but when they see the end result - makes it all worth it.
    183.9 KB
    181.4 KB
    173.1 KB
    157.1 KB
Wow!
Well done, looks brilliant. How do you cut the names inside the letters, I cannot see where the starting hole could be?
Yet another fine piece Toesy. It must have been hard cutting those names in such a large piece. May I ask you what font you used for the names.
deema":fxuq4fls said:
Wow!
1mm thin drill bit, via a press drill to keep it vertical.
Font is Liffey Script SF in Bold
Many thanks for the kind words, it takes as usually as long to cut the internal names as it does all the outside.
Hi toesy,
This is outstanding you must be so proud, as must your family at being celebrated in this way. you're an inspiration!
Chas
Oh wow toesy, don't know how I missed this. What a lovely piece of work by you.
Give yourself a pat on the back as you really deserve it !
Lovely piece of scrollmanship.Will motivate some of us learners to aspire to. thank you for the inspiration.
Have to agree with the comments above amazing quality scroll work and the finishing detail is excellent, I still can't imagine how you cut the tiny names...... what if you cut one slightly wrong when its almost completed? I would be tempted to stop once i had the large text done lol
Have to agree the work is excellent, I would be more than happy to cut the main lettering out neatly and give up on the small text!
Absolutely amazing craftsmanship your cuts look flawless
I cant emphasise enough how good they are well done
I mentioned before i want to try lettering now i have something to aim for
Thanks for sharing
