The E C Emmerich Bowsaw
Allan Fyfe
25 Oct 2007
Aberdeenshire, Scotland
The ECE bowsaw is about the right size for me; it takes a 600mm blade, is well made and the handles don’t rotate easily when the saw is tensioned up. A range of blades is available, but only the narrow one is for curve cutting, the others allow you to cross cut or rip with a big limitation imposed by the central strut – the “throat” is only 120mm.
Steering the blade, or coming back on line is easier said than done. Don’t try it using the middle of the blade – use the ends, cut near the handle while taking any pressure off the saw. Just run the saw back and fore in the groove putting turning pressure on the handle.
Make sure the teeth are away from you so that you are cutting on the push stroke.
It’s boring I know! But, practice makes perfect! The bowsaw will reward patience and a good bandsaw is expensive.
