Ttrees
Iroko loco!
Hello folks
Been wanting to do a few jobs with my tablesaw, fence abbutments and a flip down outfeed table
from some old box iron, and am wondering why not make the take off table a bit wider,
as I could utilize it for an outfeed table for an overhead bench mounted router stand setup.
I've only just started searching around for a good look at one, but not found a good video on one.
The closest thing I've seen, what's not the large overhead pin router machines, are folks using their pillar drill
table, what looks fairly awkward by comparison to the usual concealed router in a box/under a plinth setup.
I'd love to get a good look at one, just to see how much work might be involved,
like whether one needs rack and pinion etc, or tight fitting hefty 25 or 30mm rails with lockscrews
should something functional be possible to weld up.
The saw is on a wide base to accommodate the fence rail extensions, so possibilities endless regarding that .
Kinda thinking of this down the road, and would like to get the saw sorted first, practicality wise with a proper outfeed.
i.e much procrastination, whilst pondering what other uses for long lengths of very rusty box iron might be good for, quite a lot of stuff when I started thinking about it,
and figure tis worth salvaging from the elements.
I've got nearly as much as that again,and plenty of skinny rods so it wouldn't be wasteful.
Tom
Tom
