memzey":1f7yl26c said:
OwenRS":1f7yl26c said:
Who's got a wide Tersa block but never uses the full width?
My block is 12" but I generally only use about half of its width.
Tersa Money Saving Tip No.2
We all know of the 4 major grades of Genuine Tersa knives, Chrome, HSS, M+ and the Carbide. People are hesitant at times to step up the grades and to see the advantages each grade gives. Remember one knife will do all but not to its optimum. To Save the most amount of Money you will have to match the right grade of Knife to the right application.
Right that all said and done. Lets say on your 12" (310mm) wide planer you have always run the HSS grade and machined a variety of timbers. The next job you pick up is for a batch of planed up Oak of lets say 2" x 1" and you want the best finish, and for the knives to last a long time due to you having a good pack of it to put through. The best blade for this would be the Carbide which do carry a premium to buy. The second best would be the M+ grade which will give the same style of finish but this will have a large come down from the Carbides tool life and need changing more regular.
Money Saving Tip coming right up. . . . . Who says you have to buy a 12" (310mm) carbide knife???? Just by an 80mm carbide knife and slide it to one end of the block and then buy a standard 230mm Budget Chrome knife and insert it into the same knife slot in the block. You can then choose to do this in all 4 of your knife slots or choose to follow
Tersa Money Saving Tip No.1 and repeat this in two of your four slots with the other two simply having 12" (310mm) chrome knives in. Double saving.
From a machinist point of view I would then make an MDF board that hooks over my infeed table limiting the table width to the 80mm on the same side as the location of the carbide knives. I know some ones bound to point out I said we have 2"(50mm) wide Oak and I have suggested an 80mm knife, this is just in case timbers wonder while passing through the machine. If you make the MDF infeed limiter right you could reduce the 80mm Carbide knife further saving you even more pennies.
This method can be applied to all Genuine Tersa grades due to the high precision of all of them from one manufacturer and it is not just limited to the Carbide grades. Simply follow the above for the M+ or the HSS.
Again Please Keep Viewing For More Money Saving Tersa Tips.
