Hi all,
I have a Draper 16 inch 3 hp bandsaw it has flat tires and came from Draper fitted with a 1 inch wide blade 4 tpi.
The flutter method of setting the blade tensions seems very accurate. Though I wasn't very happy about having 10 inches of unprotected hook blade wizzing around. So I bought a Dakin Flathers tension gauge,which actually compared to other brands, was a quite reasonable price of £185.
I've backed off the side bearings and thrust bearings upper and lower and removed the throat plate.
The Flathers gauge instructions say, " Place the tension gauge on a slack blade, there should be........' just enough tension '....... to keep the blade on both wheels.
On the saw itself I released the quick release tension lever to fully release the tension. Put the gauge on the blade, but the weight of the gauge causes the blade to move down and the gauge is resting on the side of where the throat plate sits. I don't know if the gauge resting on the table like this alters the reading?
Anyway, I then zero the gauge and reapply the tension with the quick release lever I then got a reading of 20 psi and 24 psi at another try.
With the 20 psi reading. If I take the gauge off then back on and rezero the gauge then release the tension gauge I get a reading of 17 psi.
To try to set the bandsaw up correctly I'm referring to Lonnie Birds, " The Bandsaw Book ", as an authority. He says most blade manufacturers recommend 15,000 psi to 20,000 for a common carbon-steel blade. I have contacted Draper and chased them up, asking what the tension for their blade should be and the maximum tension the saws frame can take, bi-metal blades etc, so don't know if maximum tension frame can support comes into the equation?
I've found Draper support is almost non existent no reply, response on this from them.
I'm also refering to Mark Duginskes, " The new complete Guide To The Band Saw " Regarding tracking the blade, " A wide blade can be tracked close to the middle of the tire or with the teeth off the front of the tire. If the blade is coarse, ( as mentioned earlier the bandsaw has a 1 inch 4 tpi blade on it ) If the blade is coarse or has carbide or bi metal teeth, it is better to have the teeth run off the front edge of the tire so they don't damage the rubber material. "
I Googled and I understand 4 tpi is a coarse blade?
Should I track this blade with the teeth off the front edge of the blade? Also I'm thinking positioning the blade teeth and the blade guard might be too close, and if something..... bad happened, the blade might chew into the guard?
See attached,may make clearer my concern on this point.
Cheers.
Cheers.
