katellwood
tomatwark":2yde6kd6 said:Other thing to note that if you buy whitehill heads, you won't need a 30mm socket.
Whitehill heads come with their own special nuts, if buying second hand make sure they are with them.
Otherwise you will need to go to whitehill for them.
are you sure about this, I've seen photo's of alternative fastenings however then seen to facilitate fitting a 30mm bore with a top inset block to a 20mm shaft.
The photo's on Whitehills website do not show a special nut either in the main picture or in the block spares list
I have a 30mm block which I would like to fit to my multico if these nuts exist i would be interested in sourcing one
