Here's what a single large dovetail would look like, also just knocked up in FusionView attachment 108915View attachment 108916
I have a walk through with loads of pictures, but it's the same as the Colonial Williamsburg video and theirs is much prettier than mine. Let me know if you want it.I've got so much scrap in this workshop, I'm going to start practicing before the big build commences.
Thanks for the pic, appreciate it.
I had the impression from your comment you had a proper workbench for working on.
With space a concern, this proposed table with integrated machines will be far too wide, if you're intending to do any handwork, you need a proper bench to fit in the workshop too.
A recent thread on this below is likely something you will end up with.
I would have a pair of benches in that cozy workshop insead of the big table, and do away with anything that will have space not utilized.
https://www.ukworkshop.co.uk/threads/small-workshop-layout-ideas.130215/#post-1465293
Tom
Well I think I have a decent grasp on the shape and how they connect, be interested to know the measurements you have used, as a frame of reference.
Make space for a work bench and don't make any compromises.I will still have room for what I intend to do in here, by saying small - I mean it's not a huge space, but I've worked it all out, I will have plenty of room, especially as I intend to use the workbench for storage as well as working on.
Then make the machines safe around your workflow.
I'd be worried about hitting the riving knife and getting shavings caught in the saw personally, and that's off the top of me head.
Not too safe to have stuff on top of what now effectively counting as the saw.
The bench is likely where you will spend most of your time.
You would be hitting your knees if planing something wide, as there is no overhang, so if you decide to go that route, then set the storage area into the frame where you'll be planing.
Tom
