@doctor Bob
I have a few telescopes and a few mounts to go with them. I also used to teach and do viewings at the Greenwich Observatory so have some idea of what is out there.
1. Astronomy is fun and you can do it cheaply.
2. Once you really enjoy it, you can also spend a lot of money
You think buying tools is expensive, wait until you see the price of astronomical glass
3. Start small. You can do an awful lot with a pair of ordinary (and decent) binoculars costing £50 new. Lower magnification is probably better than a pair of 20x80 binos that you can hardly hold. Since you are on this board, build a parallelogram to hold the binos up. (
parallelogram binocular mount plans - Google Search)
4. The mount you use is just as important as the telescope. Do not put a larger telescope on a small and unstable mount. All you will see is wobbly stars and planets. If tou can build a simple wooden tripod to help, thats great. This is one of the two main problems buying a scope.
5. The first main problem buying a scope is there is so much garbage out there. Look on eBay and you will see hundreds of ads for 'professional' telescopes, with oustanding magnifications. That's complete b0ll0cks. The mounts are junk, the lenses are plastic or cheap glass, they have very long tubes (focal length) to get rid of chromatic aberation (distortion and false colour around objects). Theoretically you can get 800x magnification but the result is so dim and out of focus that it's pointless.
6. Avoid anything with the name Tasco, just about anything with the word professional in. The best telescopes do not advertise themselves like that. Anything with a kid pointing at the stars or moon. Anything with a mount that has a half circle mounting ring under the telescope. Anything that advertises something like 675x magnifcation. Anything with the word Kid in the title, In fact ignore just about all of the eBay stuff unless they have the following names, Celestron, Meade, Televue, Takahashi (look at their prices and wince), Skywatcher, Altair, Williams Optics, TAL (Russian telescopes, built like a T34 tank and remarkably good value, though a little dated). Also the cheap Celestron and Meade stuff is pretty rubbish. made down to a price.
7. Avoid astrophotography unless you have deep wallets and love suffering, frustration and downright pain. Ask me how I know!
8. The Dobsonian telescopes are probably the best entry level scopes. These are reflectors rather than a refractor, so they have a mirror at the bottom of the tube and a small mirror at the top. They use a very simple gun turret type base which is great for quick viewing and setup. The alternative to the gun turret or alt-az mounts are called equatorial mounts. These need to be setup very carefully, point a fraction off Polaris, be perfectly level and then you can track the stars with a simple motor. However they are very, very tricky to get setup right, we're talking about perhaps one - two degrees of turning of a screw in two dimensions and perhaps less. I wouldn't advise an equatorial mount as your first mount.
9. Aperture costs money, aperture on a refractor costs a lot of money, the cost goes up as the square of the radius of the aperture and then sometimes by the cube for the big telescopes. Costs for a reflector are fairly linear as making a mirror is a lot easier than configuring 2-3 bits of glass.
Something like this
https://www.ebay.co.uk/itm/294467545146?epid=25032157393&hash=item448fa2283a:g:KNgAAOSwYDRhauDM
is way under your budget and this allows you to buy eye pieces. Reputable brand, decent aperture at 200mm, simple to use as you point and look, then nudge, look, nudge and look. You will get very good views of Saturn, Jupiter and their moons. You'll see Messier objects (these are clusters of light).
One of these though
https://www.ebay.co.uk/itm/393634129649?hash=item5ba66c26f1:g:ascAAOSwor1hbERE
will probably drive you up the wall. Good telescope tube as all it is a tube, two mirrors, two bits of plastic to hold the mirrors and a focuser, However the mount is junk, the motor is rubbish and it'll just wobble. The Dobsonian would be a far better buy.
You can of course buy a refractor telescope, these would be the ones most people think of. The cheap ones are rubbish e.g.
https://www.ebay.co.uk/itm/224645677970?hash=item344ded0392:g:zQsAAOSwIIRhZpfuhttps://www.ebay.co.uk/itm/255082455356?epid=28011377692&hash=item3b6419613c:g:h7gAAOSwkLNhDuK2
The decent brands are excellent but you get a lot less aperture (light gathering) for the money. This one is an exellent bundle but it's 'only' 73mm of aperture vs 200mm for the reflector.
https://www.ebay.co.uk/itm/334183505718?hash=item4dcee39f36:g:4ckAAOSwmwdhaq7M
I have the smaller brother of the above, a Williams Optic ZS61mm for Astrophography and it's superb but that;s all I use it for. You have to add in a mount for most of them, a decent Alt-Az mount is £150+. Something like this
https://www.firstlightoptics.com/al...sky-watcher-az5-deluxe-alt-azimuth-mount.html
So if I had £400, what would I get? Check out this page
https://www.firstlightoptics.com/beginner-telescopes.html
I'd probably look for a new (
Dobsonians | First Light Optics) or just second hand Dobsonian telescope. You will probably need a laser collimator to check the alignment of the mirror if it's second hand, but thats a nother subject altogether.
If you fancied a refractor, then open your wallet and just don't look at the prices
e.g.
https://www.firstlightoptics.com/startravel/skywatcher-startravel-102t-ota.html
and see if you can get a decent alt-az mount for circa £200 which shouldn't be a problem.
If you have any questions, just ask
Rob
My scopes
TMB 100mm F8 Refractor - Visual use mainly. Superb scope for planets. This will be buried with me when I go.
Borg 76mm refractor, travel scope. Fantastic modular scope.
William Optics 61mm refractor - Dedicated for astrophotography
Lunt Solar Scope 60mm
Home made 9" Dobsonian reflector - Brilliant for demos and Saturn, the moon and planets
EQ6-Pro mount - Far too big and heavy
Giro II Alt-Az - Grab and go mount
EQ1 mount - Brought to find out how rubbish it is and it is.
Too many eye pieces to count.
