aforjeh
Hi All
Our house is a converted barn with exposed beams throughout all the rooms upstairs. Due to the layout of the ceiling, much of the room is angled ceiling with beams, so if they aren't at eye-level you are most likely about to crack your head on them.... so they are quite in-your-face, rather than 'up and out of the way'.
Over the years the beams have seen some abuse, possibly some previous efforts at renovation, and many leaks creating watermarks everywhere. The leaks have recently been fixed, and I'm wondering what can be done to improve the appearance of the beams.
Things I'd like to improve:
- Consistency of appearance i.e. colour - The other half would not 'mind' if they ended up a bit lighter, I don't mind so them as they are but would like to avoid just blanket making them a lot darker
- Reducing the appearance of water marks/stains left over from the leaks
- Getting rid of some of the paint 'overspray' and half-gone finishes
I'm not averse to spending some time on it, but would rather not sand them into oblivion (due to the amount of dust it would create, and also because I suspect the 'rough' nature of the surface (cracks & splits, grain, general 'non straightforward' bits and old ironwork etc) might mean it would take a lot of sanding to get decent results. I'm open to being persuaded though.
I'm not bothered about correcting any splits/cracks/misalignment etc, more 'cosmetic' improvements as noted above.
Some photos... probably 15% of the beams shown here, just to give you a flavour...
#1 - Beam on the right is quite dark/maroon sort of colour, then as you go left they are a lot paler, and there are watermarks everywhere
#2 - more watermarks (note I have fixed the plaster ceiling section, stain blocked + painted over so that's done at least!)
#3 - there are the vague remnants of some sort of finish almost entirely peeled off and gone with the wind... and some paint speckles (not mine, your honour)
#4 - Several years of ingrained paint
#5 - not sure what this is. Some sort of Christmas themed white 'rot' but it's solid...
Any thoughts/advice appreciated!
Aaron
![IMG_5897.jpeg IMG_5897.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130739-IMG-5897.jpeg)
![IMG_5891.jpeg IMG_5891.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130740-IMG-5891.jpeg)
![IMG_5892.jpeg IMG_5892.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130741-IMG-5892.jpeg)
![IMG_5894.jpeg IMG_5894.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130742-IMG-5894.jpeg)
![IMG_5896.jpeg IMG_5896.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/130/130743-IMG-5896.jpeg)
Aaron
