This is one for the plumbers, when I put taps on baths and pot ware I bead them down on plumbers mate and I use a brass nut and I have good spanners. If things are tight on the off set bath tap I use a flexi. Now this mate of mine says he will not use flexies cos he says you need the plumbing to hold the tap ?. All my taps have been ok but he has bother when he has used flexies. Back in the day it was boss white then putty then boss white again. What are your tips to make sure that taps don't move about after fitting ?
Cheers tbone
Cheers tbone
