MMUK
Harbo":1je8gezh said:Another thing with the Clarke ones are they are also not consistent in size - I had to work through all the 3 types to achieve the correct tap size!
They're not supposed to be. You need to use them in order - Taper, Second and finally, Plug. Each different tap cuts a greater amount of thread as you go and you don't get a full thread cut until you've used the Plug tap.
