Taking Photographs
Blackswanwood
Still Learning
17 Nov 2018
North Yorkshire
I didn't want to hijack/distract from the thread asking for advice on buying a camera so thought I'd ask my question separately ...
I find that taking "holiday" type pictures works fine on my iPhone but taking pictures of the boxes I make is a lot harder to get right. The colour often looks different. My method is stick it on the corner of the bench (preferably on a sunny day as I have cold LED lights), point, perhaps zoom a bit/move the bench light around and shoot.
Are there some simple rules/tips that should be adopted by photography numpties like me to increase the odds of a better outcome.
You really have opened a can of worms with this one.
First rule is not to mix light sources. Natural light colour changes thorough the day, or even by the colour of the room, so you want to use artificial light arranged to look natural, or wholly natural light, and set the white balance of the camera for that source.
Get a couple of reflectors, any piece of white board will do, to reflect light into darker areas.
Shoot in RAW, and process to give the result you want as well. If you don't have a RAW converter try RAW Therapee. It's free / open source.
What result are you trying to achieve though? "Natural setting" "seamless white background" "seamless other colour" or "isolated on white"?
Whatever you won't get satisfactory results without taking time on the setup.
You don’t mention which model of iPhone you have so not sure if you can shoot in RAW. My suggestion doesn’t rely on RAW.
1. Purchase a grey card / white balance card. They can be card, plastic or fabric.
2. Use the card to set/fix the white balance on your iPhone. The card should be in the same light source as the object you wish to photograph.
3. Take the photo. Set the white balance again if the light source changes.
The above should get you closer to an accurate colour rendition but do be aware that different screens/monitors may show a different rendition due to their different calibrations.
Good job you only mentioned photography of boxes. If you were also taking photos of your sharpening technique the thread would go thermonuclear (possibly).
Ah I missed the fact that he's shooting on an iPhone. I thought that was at other times. My mistake.
Also, I wasn't saying that the OP absolutely needs to shoot in RAW, just that in a lot of cases, it's less damaging to make any changes necessary.
If you can't use RAW, just use what you can. Preferably uncompressed images.
Just a few ideas:
A plain background that doesn't distract. Some white paper on a roll is ideal. Wide enough that it can be placed some distance behind the box, so it will be out of focus and look smooth, but will fill the frame behind your boxes. By concentrating more or less light on your box and not on the background, you can make the background look any shade of grey.
You can do still life photographs with all sorts of light, but a main light and a fill in light is a classic, simple combination. The main light does most of the work. The fill light lightens up shadowed areas so you can still see detail in them. It is very common to put the main light above and to the side of the object shining down like we expect sunlight to fall. The fill "usually" comes from the other side (say 90 degrees around) and is less strong.
Another way to achieve this is ambient light for the main and one artificial source for the fill, but you need to match the colour of the fill to the ambient at that time. So this adds complications.
Small bright sources of light throw hard shadows and reflections. Diffuse light sources are much softer and have a different feel. This is an aesthetic choice. Look at the Wera Tool Rebel adverts. These are high contrast images taken with small bright light sources.
I imagine soft light will work better for your boxes. Shine bright light through a biggish sheet of paper or something white and translucent to soften it.
Bring a light closer and it becomes effectively bigger and softer.
Move it further away and it becomes effectively smaller and harsher, but of course dimmer.
Lastly. Take a few hours over this. Watch some youtube about tabletop or still life photography and don't get hooked on the gear. Just experiment with a couple of battery or desk lamps as main and fill. Try pointing them from different positions like they do in the videos and look at the effect they achieve.
Take a ton of digital snaps and see how they look.
They call it painting with light for a reason.
This is the biggest problem, I think - creating the sought-after digital file means little unless the screens it's to be viewed on are correctly calibrated, and 99% of the ones showing your box photos won't be, which can lead to a lot of variation.
When you say "colour often looks different" do you mean that the colour of the boxes don't look correct (vs real life), the colour of the boxes appears to vary from shot to shot, or both?
As others have mentioned, poor quality (especially cheap white LED) lights often have gaps in the spectrum of light they produce (see https://en.wikipedia.org/wiki/Color_rendering_index), and that can make it almost impossible to get good colour in an image. However, if you're shooting in daylight then that shouldn't be the issue.
When you take a photo with a digital camera the camera's "brain" will attempt to guess that is white in the image, and will shift the colours in order to try to produce something it thinks will be realistic. However, even small changes to the composition or lighting can change the guess, and result in a series of images that appear to have slightly different colours. As Sideways has mentioned; a plain background (either white or neutral grey) can help; especially as many photo editing programs have a white balance tools; whereby you can click on the background to indicate what should be considered neutral white/grey. As long as the lighting hasn't changed too much between shots (e.g. bright sunlight + shadows changing to overcast) then you should be able to get a series of photos reasonably consistent.
If you can shoot in RAW then it's telling the camera to write out a (theoretically) completely unmodified set of readings direct from the sensor. The automatic white balance that's applied to JPEG files can (if it gets it really wrong) do enough damage to the colours in the file that it's hard to correct. The RAW data will contain no white balance adjustment - it's literally what the sensor saw, so is preferable to work from if you can.
Here's an (extreme) example - taken in absolutely terrible (low energy lightbulb) light. It's exactly the same subject, just with the camera moved slightly between the two images. Both the (automatic) exposure and white balance are very different.
Because I included a bit of white card at the top, I can tell my editor (in this case, an ancient version of Photoshop) to white balance on the card. Both images are now pretty neutral, but the exposure is still different:
Finally some tweaking of the exposure has got the subject reasonably close in both images:
It's still not great (poor phone camera, poor quality light, everything in the camera on automatic), but much better than the shots straight out of the camera. If your phone has a "pro" mode you might be able to fix the exposure and white balance settings when taking a series of shots. At least that way they'll all be consistent (as long as the lighting doesn't change).
this is a subject that can be very problematic. As was mentioned in the thread you have to ask yourself how important it is as the people viewing the image will not be using colour controlled devices.
I have both grey scale and colour targets which are used as well as a colour spectrometer for calibration. I use custom profiles for my camera, display and printer. I am often horrified how images look on other people’s screens.
In a previous job I had to take a lot of close-up photos of test samples trying to show things like cracks in black plastic or wear patterns on plated surfaces. We purchased a cheep pop up light box which came with various colored paper back grounds and adjustable light level. It really improved the quality of photos for reporting. Not sure if it would suit your purpose or not.
Thank you to everyone who has chipped in here. There are some really useful pointers and I’ll find some time later in the week to try them out. I’ll probably be back with questions!
One further thing to try, which appeals to my sense of 'economy of means', is:
Put the box somewhere outside, or inside but surrounded by natural daylight softened by clouds (not direct sun);
Take the pics as you would normally, with your iPhone;
Open the edit function on the phone, sharpen the image a little (always looks better on the net) and slide around the colour balance, saturation and contrast until you get, on your phone screen, what looks most like the figure in the box;
Post to the internet.
As said above, you can't determine how the image will appear on other people's screens, so no point worrying too much about that - make it look right on yours and that's as good as you can do. (y) :)
For total control over the output image then there is no other format to shoot in. Why, well it allows you to set the color space on the Pc and not in the field, unlike a JPEG any editing is non destructive and in the field you only have minimal settings to worry about. For your application it is going to be a game of experimenting but the first thing is a non reflective neutral background for your box and then play with the phones settings as those things seem to be all about presets and instant images so getting a good enough image must be possible.
The main thing, apart from all the technical stuff, is to actually look at the screen, or through the viewfinder on a camera, and see what you are shooting.
Look, really look, at the potential shot, and see the actual arrangement and if there are any problems obvious. Dark or blown out areas and so on. Think how the subject is framed in the shot.
Even a simple product type shot should "tell a story" as much as possible.
"This is a hand made item of extremely good quality" for instance.
Lighting and positioning can make all the difference.
One of the most important aspects of photography is without doubt, light/lighting.
Without making it too complicated, if you're using natural outdoor light with an iPhone to photograph your products which can be ideal and better than when using artificial light, then might I suggest you defer the taking of the images of the products you've made until ideally you have a bright but overcast day where the lighting doesn't create any distinct shadows. It's much preferred to strong directional sunlight if you want an evenly lit subject.
Light from the North is by far the most evenly dispersed light having passed through clouds which will provide very soft or even no shadows if correctly balanced with perhaps white paper reflectors. Bright but cloudy conditions with no direct sunlight falling on the object/subject is the ideal with any shadows filled with reflectors..
North light is ideal for portraiture too especially if again supported by such as fill flash or white reflectors. The flash on an iPhone can also help create distinctive portraits outdoors if you can get the balance between the flash and natural light correct.
If you're struggling to get the correct colour balance, as was mentioned by another poster earlier, get yourself a recommended grey card to use as a reference for your WB.
By including such as a traditional Kodak Grey Card or whatever brands there are these days somewhere discrete but within the frame, you can adjust the white balance perfectly when you use editing software.
What country are you in, Tony? Light from the North to take photos in UK? (I'm having one of those head-spin moments.) eta - Are you thinking of a room with a window just to the North? Trying to understand. (y)
I'm from the North East of England Chris sorry if my explanation confused you but looks like you understand it now :)
