tables
gwaithcoed
23 Feb 2005
North Wales
A request from SWMBO. “Could you make something that I could give for a raffle prize at the Christmas fair.”
“ Anything will do, maybe another little table like before”
“There’s also another two raffles coming up at the golf club for the Christmas competitions, do you have enough wood to make two for those?”
That was it then, so off I go to see what is available.
I found a couple of lengths of 3x3 that was left over from a job I did for my daughter.
These were cut into lengths of 16 inches and then cut into four on my new SIP bandsaw (gloat)
They were then surfaced planed to give me a square face side and face edge.
Then through the thicknesser to give me a 1 ¼ inch square leg.
Next the ends were squared off and the legs cut to their finished length
The mortice was then marked out on one of the legs,(the others all marked with a centre line) and
using my home made morticeing jig and router all of the mortices were cut with a 9mil straight cutter
The next job was to taper the inside faces of the legs, and this was done on the table saw with a tapering jig. Each leg was then passed over the surface planer to remove the saw marks and sanded on the bench sander.
The outside edge was then rounded over on the router table using a ½ inch ovolo cutter
Making the top was the next job as each one was to be fitted with a 13 inch square floor tile.
The sides were made from 6x1 cut into equal widths and planed up to give a finished size of 1 ¼ x 7/8 and about 17 inches long.
These were then taken to the table saw and passed over the saw blade to give a groove into which to fit the 6mil plywood.
They were then cut to the correct length on the mitre saw, and glued around a piece of plywood, clamped and set aside.
Now that I knew the exact size of the tops I could now cut the rails as I wanted the legs to be a snug fit under the tops.
They were cut from 6x1 giving a finished size of 2 ¾ x ¾ .
After cutting to the correct length the tennons were cut on the table saw.
The lower edge of each piece was then rounded over on the router table and the end of the tennons cut at 45 degrees as the tennons met one another in the mortices of the legs.
Before gluing up a dry fit was done and then each piece given a coat of dark oak stain. I find it better to stain before glueing.
When the stain had dried the legs and rails were glued and clamped.
When the tops were dry, they were taken out of the clamps and sanded with a random orbital sander. They were then taken to the router table to have the edges rounded off with a ½ ovolo bit and given a coat of stain.
The tops were then fixed to the rails with screws, ready to be given two coats of satin varnish.
They were left then for about three days before the tiles were fitted in place. This was done using a bed of tile adhesive and the tile pressed firmly down until the top was level with the sides.
After 24 hours the gap around the tile was filled with grout
And here are the finished tables
Christmas morning will tell me how many brownie points I scored with this project.
Thanks for looking Alan.
hmm seen that sheppach p/t somewhere else today... :-k :wink:
They look fantastic, did you start and finish all of them in one day? Please don't say yes! :oops:
Very nice,and lots of photos - thanks! (The photo's must have taken about as long as the tables,didn't they :wink: )
Andrew
Nice one Alan, i am sure that Mrs Alan and the prize winners will be over the moon with prizes.
Regards
Woody
Alan,
Nice tables, I hope the brownie points are received, I'd like two strips of tickets please. :roll:
On the tool front, where did you get those blue clamps? I have some of the red style but blue one look as if they have deeper jaws. 8)
Hi wiZer, would have done but couldn't find the quick drying glue :whistle: :whistle: :^o :^o :^o
To DaveL, The clamps were bought some years ago when the woodworking shows were at the N.E.C. Can't recall seeing them anywhere else
and to Power Tool, I must admit the photo's did take a while,not my best subject, kept going to the preview button to make sure I was still on track.
Alan.
Very good - and a great photo-story too!
Adam
Top work , did you get confused with so many parts ? I go half mad when doing production work :lol:
