I was looking at a US woodworking site and there was a number of postings regarding burn marks when ripping hardwood on a table saw. Some bright spark suggested that the blade may be blunt, to slow a feed and or there were to many teeth.
Then to my amazement there were several posts recommending the following; stick abrasive circular discs to each side of the blade so that the outer diameter was just below the gullet, use the saw as normal the blade cuts the abrasive sands the edge at the same time: therefore no burn marks. This appeared to be common practice, but it was at the beginning of April, so I wonder.
